Hi, anyone know where I can get the YS Tech 80mm 47cfm fan? Thanks. :)
S Sniper564 Registered Joined Apr 6, 2001 Aug 1, 2001 #1 Hi, anyone know where I can get the YS Tech 80mm 47cfm fan? Thanks.
E el Guest Aug 2, 2001 #3 everyone has them. which model # are you looking at? do a google with the model number.
E el Guest Aug 2, 2001 #4 http://216.157.14.244/fans.htm no 47cfm 80mm has other good fans. isn't 47cfm a lot? try the panaflos 80mm 12H give 40 adn are silient.
E el Guest Aug 2, 2001 #5 Sniper564 (Aug 02, 2001 01:22 p.m.): Anyone? Click to expand... 10.75 http://www.subzeropc.com/store/fan80253c.htm
