I found some DVI cable, but I'm confuse of which one to get. Below is a link where I've found those cable, but then one say single link and a dual link. So I'm confuse of which one that be compatible with my NEC 1760NX and the Sapphire 9500NP. http://www.bonuscable.com/default.php?cPath=465
If anyone out there with a similar LCD and vid card that used DVI connection, please help me out here on how to choose the right DVI cable.
I just recentlly purchased a 1760nx and am too looking for a dvi cable. My card supports dvi-i. Should i get a dvi-d single link or dual link. whats the difference? thanks.
Your card supports DVI-I, which mean you can use both DVI-I and D. You should get DVI-D since the monitor supported that and get dual link( I read it somewhere that it should be better than single). The link below is where I got mine. It was $9 dollars when I got mine back in august, it's $13 now. It might not be the best cable, but IMO it look awesome(probably not close to monster cable, but consider I only pay $9 and monster cable are like over $100). And I have check the different between monster cable and mine, and to me it not noticably different.
I was going to order like from newegg and all those retailer, but they charge to much for dvi cable, that are not even monster cable.
