Hello OCforums, i'm looking at geting either an ABS G4 or G4 revolution. I'm looking itno pn-moding it to run at 2.13GHZ but i need a diagram to do so. It would say a lot on money if i could do that.
DOnt mind that this is for the dell 9300... the pin goes in the same spot in the socket no matter the machine, as long as you have a 400fsb cpu and the 915 chipset you are good to go.
it is not the laptop but the cpu that is 400fsb, and yes, after the pin mod the FSB will run @ 533, its a waste of money if the manufactur'r offers both. However since most don't; a lot of guys will just buy a 400mhz chip and then pin mod that and sell the 533 on ebay.
