- Sep 4, 2007
- Uppsala, Sweden
Hello all!
Well I've finally made my first steps in the world of overclocking. And went facedown hard
I'm working on reading the guide in the sticky, but was also going by the following info given to me by PM:
I've tried at first with FSB at 400, multiplier at 9. Forgot the vcore. System won't do much, starts for some secs then shuts down and tries again, over and over. Then realized I forgot the vcore, so after clearing CMOS tried with vcore 1.35V (being careful), FSB 400 and multiplier at 9. Same. Raised vcore to 1.45 and lowered FSB to 350 with multiplier at 10 (optimized BIOS defaults, F7). Same.
I'm not really sure whether I need to pump up the vcore more, or if there's other settings which I should change.
I'm running a X3230 ES on a Gigabyte GA-P35-DQ6. I've not changed anything else, figuring I'd ask here and read on in the overclocking guide first.
What causes the system to shutdown straight off? CPU temp? CPU instability? Why is it unstable, too low voltage or such?
I'm all new to this so I don't want to crank things up too much without knowing what I'm doing.
*edit2*
The guide doesn't really give much more info, not in the main post anyways. So any ideas on what's the bottleneck are welcome!
*edit*
Might add that the 'optimized default' runs at 266Mhz x 10 by the way.... multiplier seems to be 'unlocked' then?
Have you tried overclocking it? Just go into your bios, set the vcore to 1.4v and change the FSB to 400. If that won't boot, enter the bios again, set your vcore to 1.5v and try again. If that still doesn't work, leave the vcore at 1.5v and set your fsb to 350. That will definitely work! Keep moving the fsb upwards until it doesn't work and then come back down! Let me know how you get on. You can leave all over values on auto for the moment.
*edit2*
*edit*
