- Mar 12, 2012
If I may give my 2 cents on this topic.
Hey there all. I'm Cory and like to post this link to my build
http://www.flickr.com/photos/79553991@N05/
the descriptions in each photo contains the links of the products used
I'm also creating a video log and will upload it to youtube when it's ready.
About this build
Case: Haf X
CPU: AMD 8150 Water block EK Full Copper
MB : ASUS Crosshair V Formula Water block EK Crosshair
GPU: 2X EVGA 480 Water block Danger Den
Ram: Gskill G.SKILL Ripjaws X Series 8GB
Rad: Phobya G-Changer 360
SSD:G.SKILL Phoenix Pro Series FM-25S2S-240
HD : Seagate Barracuda ST1000DM003 1TB
PS : CORSAIR Professional Series Gold AX1200
This is my first water cooled build mod of ANY sort, I have planned this out and carefully selected every piece for the best results. it's taken a good 4 months for purchasing and 1 month for modding building.
I started with a Haf X PC case and had it striped and nickle plated.
The vid water blocks are from Danger den and the MB and CPU blocks are from EK bought through Dazmode here in Toronto.
The manifolds are build by me using a pex style manifold.
http://www.pexsupply.com/Sioux-Chief...lets-5435000-p
I went this route b/c I wanted each component to have cool water and not have it add heat every stage. The manifold is fed via 2 1/2" ins to equal pressure and flow concerns. They also have brass ball valves to help regulate flow if needed. Also and easy way to lock off part of the system IF components need to be replaced.
After a couple weeks of abuse I have yet to get the temps above 49C at full load * furmark and other benchmark tests. BF3 at ultra settings is perfect in every way
If you have any questions about this please ask
844157[/IMG]
About this build
Case: Haf X
844157[/IMG]
