- Sep 20, 2001
- Bakersfield, CA
45C at almost 400W are great temps to me. You're doing fine.
The DDC 3.1's I think are 3100rpm pumps (6-10W), where the D5 is 4500rpm maxed out. The high power DDC 3.2 (there's so many versions now it's hard to keep track) would do 4500rpm also. The difference is that the DDC rotor has a smaller intake and narrower impeller, which gives it more head than the D5 but lower maximum flow rate for a similar RPM. D5 has a much more open intake and wider impeller outlet. So, yeah, a D5 could flow 6GPM with zero restriction, but add in basic loop components and it'll choke back big time. DDC 3.1's are a nice compromise for noise, pumping power and size.
