- Jan 9, 2022
For me, loop servicing is just easier with soft tubes. There is no compromise in cooling, just looks, but i am happy with that, so will stick to soft tubing now.
I have a feeling that in about 5 years, I will be in that same position. As it stands, I would love for this system to last me 8 years, 10 if possible, but I'm doubting that.For me, loop servicing is just easier with soft tubes. There is no compromise in cooling, just looks, but i am happy with that, so will stick to soft tubing now.
After the 5 year mark, my youngest should be old enough that I can put a tower "on the floor" (on a stand) again, and use the Thermaltake Core V71 TG, at which time soft tubing will be my go to.
Hard line is purely for show, and makes sense when the tower is on the desk, but not so fun to service... The EK Torque fittings have one of the two orings about 1/16" from bottoming out, then the second ring at the top, under the ring. So ensuring each tube is fully inserted before tightening the ring is a little more obvious than other fittings I have used with the o-rings almost stacked on top of eachother, making it a little less obvious when the tube is completely seated.
Maybe you'll see some improvement if you increase the flow? Typically we ask for 1-1.5GPM flow and if I can math right this early, that's a little low?flow rate is 168LPH
"...increase the flow"How would i improve it?
Turn the pump up... or get a better one? Isnt 1 GPM = 240LPH? It's an awesome build but nkt sure why the flow rate seems low... maybe it's just me??
I see 90 degree bends (barbs) all over... maybe that's part of the reason?
To be honest, if you're at 60°C at full load, there is no need to change anything.How would i improve it?
This.......!To be honest, if you're at 60°C at full load, there is no need to change anything.
This.......!
Sorry, yes.. temps are already great (what testing is that?)... but I saw the flow rate was hella low compared to what we ask for.
Nice looking build.
Indeed.Tbh i don't think it's that bad even with CPU at 100%. i can try and see what it's like. I am not really in benchies R23 etc, any more so as long as temps are ok for gaming and general use it's fine for me.
Indeed.
Typically people run worst case scenarios (stress tests) to see what's up... but if that's all you're doing, and temps are fine, no need to touch anything. Im guessing the amount of radiator you have helps out a ton here with slow flow.
