- May 29, 2005
Hey all,
I am working on my next review featuring the Accelero Hybrid 7970 cooler. So far I have attained numbers for the TwinFrozr4 cooler that came on my 7970 Lightning and the numbers for the cooler itself. I am looking for someone that has a 7970 with a different cooler than the two listed (preferably a reference cooler, but if others are available for testing I would gladly include them as well). I want to keep this with just air coolers as a full water loop has way too many variables.
My testing parameters:
If anyone has the time to help me attain the numbers for this I would appreciate it.
I also am trying to keep track of the dBA (decibel level) of the coolers with the fans at maximum speed. I use a sound meter, if you have one available that would be great, if not we can make a note.
Anyone that helps me out will be mentioned in the review
Let me know if you have any questions. I personally keep track of my numbers via a google doc that I would share access to for easy editing for anyone able to help.
Thanks all!
- Room is kept approximately 24C (approximately 75F) - I do so via a window air conditioner unit.
- MX-2 thermal paste (to stay consistent)
- I use a benching station (not required, but nice for consistency)
- GPU Fan set to 100% (or 12v)
- Temperatures measured via MSI Afterburner, noting the idle temperature and the peak temperature under the load of the benchmark (min/max basically).
- Benchmark used is Unigene Heaven with all of the settings maxed out:
- DirectX11
- High Shaders
- Extreme Tessellation
- 16x Anisotropy
- 8x Anti-Aliasing
- Full Screen
- 1920x1200 Resolution
- I do one full pass at the settings above, then exit out of the benchmark and wait a few minutes for the GPU to get back down to the idle temperature.
- Change the vcore to the next notch, then re-benchmark.
- Vcore used is between 1000mV to 1300mV increasing by 25mV each run.
- Core clock: 925 | Memory: 1375 (memory volts set to 1600)
Thanks all!
