- May 28, 2016
That's the one they run on the same power rail. @ catastrophe set the voltage to a + offset and add the.05v like wingman said. Otherwise setting manual you need to find the right stock VID. One other thing I thought of is LLC. Try setting that to about 6 or 7. I run mine in level6 and seems to hold the voltage fairly well. LLC helps stop voltage fluctuations.
I've done both of those things just now. I'm on a stock cpu cooler right now (my old h100 cooler's power cable was funky so I wanted to eliminate that as a possibility too) but my Noctua NH-D15 should arrive tomorrow AND I think I'll put the system back inside my case (since we now know case components are not causing this). So, heating shouldn't be an issue (not that it is at the moment).
Thanks guys for the help so far. When I fix this thing, I'm taking you guys out for drinks. Not sure how to do that yet, but I'll figure it out.
Fingers and some other parts crossed
