ASRock Extreme 6 Z97 - http://www.newegg.com/Product/Product.aspx?Item=N82E16813157500&nm_mc=AFC-C8Junction&a mp;a mp;cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SI D=
Need to know if the following RAM matches. Was going to pick up the ARES in the same specs, but this one is $20 cheaper w/promo code until the 27th and since I am going to WC now, height is not an issue. Just concerned about the color, seems to be darker than the Ares and I have a pic from a forum member with the ARES and it's a really solid match. - http://www.newegg.com/Product/Produ...112114-Index-_-DesktopMemory-_-20231476-S1A6A
Also, with the Primochill LRT tubing, in the Enthoo Primo case with Helix 120 fans, I kind of figured it has to be white, black, or blue. Now, to be fair, I do not think I like black tubing, although my fittings will be black. Looks like white unless the blue matches. But, anyone have any idea how this actually looks (true color)? Does it match the above? - http://www.frozencpu.com/products/1...e_PFLEXA-58-B.html?tl=c99s1615b46&id=gLHmhUQd
Any other comments. I know Jack will comment on the theme so look forward to that!
