- Aug 27, 2001
- Dark side of hell
I just got my duallie up last night It is now folding and I am starting to move all my apps onto it as it will be my main system in the near future. It is a MSI K7D-L Master with two SMP modded XP1600's and two slk 800's the only problem I am having right now is the settings for MBM5 so if you have this board and have MBM5 working can you tell me which sensors to chose. TIA. Install went great after I fixed a little hardrive problem (had to set it to cable selct for the bios to recognise it) Well I Once all my apps and files are moved then I will mave it into my Lian Li case and I will take some pics. it is just too crowded in the case I have it in now
