These two programs are interconnected due to Microsoft's .NET policy. Next with thanks to Ice-Freezer from xp-erience.org
Tip: Easiest method to disable Messenger: C:\Program Files\Messenger and either rename the Messenger folder to
something like "MessengerOLD" or just move it.
Disable MSN Instant Messenger
Start/Run/Regedit
HKEY_LOCAL_MACHINE\Software\Po
licies\Microsoft\Messenger\Cli
ent
Value Name: PreventAutoRun, PreventRun
Data Type: REG_DWORD (DWORD Value)
Value Data: (1 = enable restriction, 0 = default)
Create a new DWORD value, or modify the existing value, called 'PreventAutoRun, PreventRun' and edit the value according to the settings above. Exit your registry, you may need to restart or log out of Windows for the change to take effect.
Remove Messenger from XP
Start/Run/RunDll32 advpack.dll,LaunchINFSection %windir%\INF\msmsgs.inf,BLC.Remove
Disable Messenger
Start/Run/gpedit.msc/Admistrative Templates/Windows Components/Windows Messenger. Alter your settings in the right pane. (For Pro)
Stop Windows Messenger from Auto-Starting
Simply delete the following Registry Key:
HKEY_CURRENT_USER\Software\Mic
rosoft\Windows\CurrentVersion\
Run\MSMSGS
Uninstall Messenger
You have to edit sysoc.inf (located in /WINDOWS/inf). Under [Components] you should see the following line:
msmsgs=ocgen.dll,OcEntry,msmsgs.inf,hide,7. Take the word 'hide' out of the line, and it should look like this:
msmsgs=ocgen.dll,OcEntry,msmsgs.inf,,7. Exit and save.
Go to Add or Remove Programs, and click on Add/Remove Windows Components. There you should now be able to uncheck the MSN Messenger Service, and by clicking Next it will uninstall.
Remove MSN Messenger from Outlook Express and Prevent the Delay
Start/Run/Regedit
HKEY_LOCAL_MACHINE\SOFTWARE\Mi
crosoft\Outlook Express. Value Name: Hide Messenger, Data Type: REG_DWORD (DWORD Value), Value Data: (2 = remove messenger). Create a new DWORD value, or modify the existing value, called 'Hide Messenger' and set the value to 2.
ent. Add the following values as New, DWord Values: PreventRun and PreventAutoRun. Set the value of each of these to1.
Slow Loading of Outlook Express When Messenger is Disabled
Start/Run/Regedit
HKEY_LOCAL_MACHINE\SOFTWARE\Cl
asses\CLSID\{FB7199AB-79BF-11d2-8D94-0000F875C541}\InProcServer32
asses\CLSID\{FB7199AB-79BF-11d2-8D94-0000F875C541}\LocalServer32
For both, in the right pane, right click Default/Modify/Delete the value data.
Hotmail is slow after disabling/removing Messenger
The side effects are not known as of yet: Start/Run/Regedit
HKEY_CLASSES_ROOT\Messenger.MsgrObject
Right click on the Messenger.MsgrObject key and select rename. Rename it to Messenger.MsgrObjectold
This will prevent Messenger from loading when you access your account via the Hotmail web page, it will also prevent the delay when Messenger has been removed or disabled.
Preventing Microsoft Messenger from Automatically Signing in
Start/Run/control userpasswords2/Advanced tab. Manage Passwords/Delete (Passport) Entries. Open MSN Messenger (click here to sign in) enter passport e-mail address and password and leave the Sign Me In Automatically unchecked.
Tip: Change the MSN Messenger Background Image
This tweak allows you to change the background bitmap image in the MSN Messenger service. Locate the installation directory for MSN Messenger on your system (e.g. "C:\Program Files\Messenger"). This location can also be found in the registry in the "InstallationDirectory" value at [HKEY_LOCAL_MACHINE\SOFTWARE\M
icrosoft\MessengerService].
Rename the "lvback.gif" file in the installation directory to "lvback.old". Then copy and rename the new background GIF file to the same directory as "lvback.gif". Restart MSN Messenger for the change to take effect.
Tip: Getting rid of ads in MSN messenger
Find its default folder (search for Messenger). Open LINKS.TXT and clear its contents. When finished, save the file and pull up its properties from the Windows Explorer. Place a checkmark in the "Read-only" field.
Remove/Add Items from remembered list in Messenger login
When you sign in to Messenger, it remembers every email address / .net passport that you signed in under. To remove an item from the list of remembered names:
1. In Start menu select Run
2. enter: "control userpasswords2"
3. Go to Advanced tab
4. Select Manage Passwords Button
5. Add or Remove items at will
