Hi there I need some help to reach 4.0 GHz (that was my initial goal).
I have this system:
mb aSrock 890fx deluxe 3 (beta bios)
cpu amd 1090t
gpu his HD5830 1GB
psu corsair tx650
ram corsair dominator 4GB 1600MHz cl 9 9 9 24 2t
ssd samsung evo 840 120GB
hdd wd caviar green 1TB
cooler arctic xtreme freezer, fan full-on with one more fan attached on the back
The thing is that I cannot move from 3.8 GHz while still pass 10 ibt runs on 1024:
I've tried only rising the multiplier as high fsb seem to be instable on +3.6GHz..
3.2-all stock (1.325 vcore)-passed
3.3-all stock-passed
3.4-all stock-passed
3.5-all stock-failed
I had to increase vcore by one notch:
3.5-1.3375-1.1500(stock)-passed
from now on I've raised both vcore and cpu/nb voltage getting to these settings:
(clock-vcore-cpu/nb)
3.6-1.3875-1.1875-passed
3.7-1.4250-1.2250-passed
3.8-1.4500-1.3250-passed (+0.1 here!)
3.9-1.4500-1.3250-failed
also
3.9-1.4625-1.3500-failed
and here I stopped returning to the stable 3.8, so I stopped and starting some work on ram and cpu/nb freq.
I got it stable to 2800 cpu/nb and 7 8 7 7 20 1t @1600 on ram..
is it safe to raise over these voltages? I've read dolk guide and a couple others but these seems the max for 24/7..
Why have to overvolt it so high, others did much more with less voltage, do I have such a bad chip?
Is the cooling inadeguate? I have 21°C in idle (room 24°C) and max temp 47°C under ibt..
I noticed, since i moved it on the desktop, that the psu make some high pitch sound when under load (4years old), can this be the sign of degradation but also of OC instability?
The motherboard should allow some more overclocking room imho! But maybe this board isn't the best (they made 3 revision of it)..
Help me please, I'm pretty desperate
I have this system:
cpu amd 1090t
gpu his HD5830 1GB
psu corsair tx650
also
