for overclocking yes.. but if your planning on just keeping it at stock clocks... the stock heatsink works fine.. heck they give you the heat sink and if you run everything stock nothing should heat up enough to cause probs. its pretty loud tho.
The stock cooler works fine for default speed or mild overclocks, but once you start pushing the O/C and especially when you have to add extra vcore, then the stock cooler is no longer adequate.
I've heard of many people using the stock cooler to get up to 3.2Ghz with the E6400 (400Mhz FSB and stock volts). Yes, the stock CPU is pretty bad, but not unusable. Unless you have to increase voltage, it's fine.
