- Jan 18, 2010
- Calgary, Alberta, CANADA!
I recently installed a new 16 gb ( 2 x 8) kit because I kept maxing out my 8 gigs. But when I tried gaming I noticed stuttering. it will look absolutely beautiful and then the frame rate will drop to nothing. This did not happen with my previous kit. I should mention that it is a 1600 mhz kit and I have it running at 1866. I believe this is a voltage issue ( lack of). I think this because boosting the voltage seemed to help but not eliminate the problem. It is at 1.5 volts right now and i have no idea where I should be putting it. I believe 1.5 is stock, but my mobo had it lower.
Specs;
Asus crosshair formula 5,
AMD 8150 @ 4.6 Ghz
2x8 Gb Crosshair doiminator platinum kit.
2 x AMD 6870's
Any thoughts would be appreciated.
Specs;
AMD 8150 @ 4.6 Ghz
2 x AMD 6870's
