- May 15, 2010
- Euroland, Denmark
Hey guys,
I have swapped my AsRock B75M-ITX for an AsRock B75M (mATX), with the intent to get another 7870, and CF them. Dont ask my why, but im nuts.
At the moment i have a Corsair GS800 PSU, which is just fine, apart from the fact that i feel it may be over doing it? (and i feel the GS800 would be better used in my mining rig)
The rig will (once done) be following setup.
AsRock B75M
Intel i7 3770
2x 4Gb Kingston 1333Mhz ram (may change)
2x 7870 2Gb CF
1x OCZ Octane 2 64gb SSD
1x 250Gb Sata2 disk
1x water pump
3 or 4 gentle typhoon 120mm.
Would a 600watt Bronze rated handle this fine? or could I go lower? 550watt?
There will be OC'ing on the 7870, but only mild oc.
AsRock B75M
Intel i7 3770
2x 7870 2Gb CF
1x 250Gb Sata2 disk
1x water pump
