- Sep 26, 2002
- Indianapolis, IN
- Thread Starter
- #21
On small complaint that I do have with Windows 8 and Server 2012 is that the search (Windows key + typing) doesn't lump all results into one category and order by relevance. Instead, it separates them into Apps, Settings, and Files. If I want to launch Server Manager or Control Panel, I have to tab down to 'Settings' and hit enter. If I'm looking for 'budget.xlsx', I have to tab down twice to the 'Files' category. On Windows 7, the most relevant and accurate result is on top... saves me a couple keystrokes.
If I remember correctly, that is going to be changed in Windows 8.1. I haven't used it yet but I do remember reading that somewhere.
I think most people who are adamantly against Windows 8 are those who are simply resistant to change...
There are measurable handicaps to using Windows Metro. Simple Reboot procedure is an excellent example:
Do you hover your mouse *carefully* in the corner, hoping to Fish-In the “Charms” pop-up, only to have to carefully scroll down to Settings thereafter, making sure that Charms doesn’t disappear?
We were actually talking about just that at work but with Server 2012. They were trying to figure out the quickest way to reboot. I think they figured that the two quickest ways were via PowerShell and using alt+f4 from the desktop to bring up the old school shutdown menu. That really cracks me up that those were the best solutions that we could come up with in terms of speed.
Actually, I press the Window key and type 'shutdown /p' and hit enter..
But, c627627, your point is valid, and I completely see where you're coming from.
[edit]
But this probably wouldn't fare well in a production server environment, as it doesn't give you the 'reason' dialog box for your shutdown.
Is there anything faster than Classic Shell Windows 8 One-Click Reboot:
Not CP. Meant the PC Settings stuff. My mistake.
Can you create these shortcuts:We can't install that on our server 2012 boxes
