Prime 95... And it loads to 100%...
Images you requested are attached.
The 7-7-7-18 is what it said on the box, should I adjust it?:
Newegg Page for the RAM specs
ADDITIONAL COMMENT:
During idle... Lol.
Keep that cpu under 75c temps are fine. But that is a lot of voltage for those clocks. Im not sure however if it is a bad cpu or that econoboard which is NOT made to overclock, can handle it.
@ Shrimp.. look at his screenshots and you.may want to edit your post....or read the whole thread.
Ya I didn't read it all....
But never the less, that ram looks odd on that Cpu-z SS I saw. mainly why I posted. I've never seen a Bank Cycle time THAT loose. 86 bro? really?? LOL, that should be as loose as 32 on a Cas of 8 and tighter on a cas of 7.
Just what I saw, figured the memory is still an issue if he's looking for more Bus at the current configuration. And that Bank Cycle needs addressing too.
Anything I missed beyond this, PLEASE fill me in!!
I honestly have no idea what DRAM timings are for or do, I just left them at the default the package said they are rated for. I can change them if you think it'll fix something. The RAM is only rated to go at 1.5v, is it O.K. to increase the voltage?
I've seen trfc way higher than that brime.
What I think you missed the fact that with his current fsb (333), and memory multi, his ram is at stock speed. So there isn't a need to raise timings or voltages. Now if he pushes further, which I am not sure what he is doing as the replies are vague at where he is at, then you would want to lower the memory multi.
Yes and no that ram is not running the SPD. I did however look at their site and they don't show Ram specs beyond Cycle time (tRAS). One of the reasons I don't by from vendors like that. Not enough specs to go by to consider a purchase. I'm sure there's a white paper somewhere if I had the time.
Try for more bus and manually set your timings. I think it's safe up to 1.65v, and tight Cas is always better, BUT if OV is a concern, try a ram set of 8-8-8-24-32. This timing set is pretty universal and basic 1.5v should run it right up to 800mhz.
Always use very small bumps of voltage on your hardware. One simple click at a time and do the same with the reference clock. No more than 2 clicks at a time.
Make sure you are not confusing tras with trfc.
I may have!! -
well anyhow, I'd go for gold. More Ram v or loosen em' up on the Cas at least and see what happens.
OP I'm talking try 1.55v and give a small freq bump of 2, leave everything else alone.
