Depending on what you are doing with it you might not even notice.
Unless you need it asap I would save up to buy the set though.
Why not 2x8GB instead of 1x16? You get the same capacity and dual channel that you're supposed to run with.
What is your system specs in the first place?
That RAM stick you want to buy is slow and with higher CL latency.
For example you can get thjs... $80 2x8gb ddr4 3000 - https://www.amazon.com/TEAMGROUP-T-...9Y2xpY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU=
Only two DIMM slots.Why throw them away? Why not add the same kit down the road when you need it.
With an APU, you aren't setting CAD on fire either, my friend.
Can you please list the rest of your system? Power supply, gpu, etc.
I'm trying to get you more capacity the most performant and least expensive way possible. CAD uses the GPU and I'd guess you don't have a discrete GPU. Assuming that thought is correct, you want faster RAM too as the integrated graphics on the APU uses system RAM. The faster it is (and in some cases more) the better that iGPU performs.
I understand budget is a primary concern, but you can get 16GB of DUAL channel and faster RAM for the same price as your single stick. Respectfully, IMO, you aren't looking at it right. When you need more, buy a second kit just like it. Simple. The kit I linked was just an example. You can look up 2x8GB DDR4 2933 kits without RGB at Newegg or your vendor of choice.
Which is why I asked for system specifications that include your motherboard... hard to know that if we don't have the info. Consider a majority of motherboards have four slots in the first place.Only two DIMM slots.
That's better than the integrated, surely.GPU (Radeon RX 550 4GB GDDR5) ordered and on its way.
We're good here, but not mind readers. Thank you for sharing the information we asked for.Only 2 DIMM sockets!
I still suggest buying a 2933/3200 stick with a lot lower CL rating. Latency and bandwidth go hand in hand.
In short, yes, you can use a single stick (read the manual for which slot to stick it in), though you're likely leaving performance on the table. How much in your specific use case, I don't know.
Anyway, please keep us posted on the results of your new stick!
Glad to see you're getting good results by avoiding the swap file.
Dual channel has been able to work with mis-matched sticks for many generations now. Years ago I had a Core 2 notebook (with a 32bit O/S) running dual channel memory with 2GB & 1GB modules.
Thank you for contacting Crucial. In response to your query, we would like to inform you that when two non identical RAMs are installed in system, the system will choose to run at speed which is lowest among both RAMs. Like wise the system will only consider the lower density i.e. if a 4GB and 16GB RAMs are installed together the system will consider it to be 2 4GB RAMs. This error is called mix match error.
I thought you were trying to avoid swapping to the slower SSD?And the ssd (recently repurposed from a TV) gives me an effective memory capacity of upto 64GB; albeit with pregnant pauses.
Flex Mode (at the bottom): https://www.intel.com/content/www/us/en/support/articles/000005657/boards-and-kits.html#flex
