Hey This is my first PC I ever built and Its fast as hell.. This is also my first time overclocking, dont worry I have read up a lot on the forums and my manual and am being very careful. I check my temps for everything and I am going in small incraments... using prime95 too
Anyway heres what happened:
I finally got the FSB up to 200FSB after raising it slowly, raising thevcore to 1.75v and turning down the multiplier to 10.5, It posted fine at 10.5x200 (2100mhz) and thge temps were 40c idle/ 43c load (after an hour of prime95 and quake3 max settings) and I was gonna run it for a long time (4-12 hours) , but I then I thought why dont I try a multiplier of 10 and FSB 210.. Which would be the same speed, but I am told that a higher FSB is better... Anyway I stopped prime and went back into bios... changed the settings and then no post. My motherboard then played its little "I dont wanna post" song and I needed to clear the CMOS...
Why will it post with 10.5x200, but not with 10x210? It's the same speed, right?
Right now I am back on the 10.5x200 w/ 1.75V and its running great with prime95, Motherboard monitor, a pop-up killer, keyboard software, etc... I'm thinking Im just gonna leave it like this and run prime till tomorrow morning see how stable it is. I just made this post so I can find out why it would post one way and not the other with the same speed (GHZ/MHZ)
Thanks a lot. So far I think Im doing good for a newbie.. gone from 1730ghz to 2100ghz.. Which is almost 400MHZ.. My last computer had only 500mhz and I could not overclock it.
specs:
Epox 8rda+ motherboard
Athlon XP 2100 (1.736 ghz) T-BredB 0302
256MB Twinmos/Winbond PC3200 DDR400
80 GB Western Digitial "SE" 7200RPM 8MB cache HD
Xtasy Geforce4MX420 PCI
nforce soundstorm onboard sound
Turbolink 350W PSU
X-sonic case
cooling:
SK-7 heatsink w/ Smartfan 2
2 case fans (guessing around 25CFM)
I am going to upgrade this a bit, I just didnt want to wait for 2 weeks for the next check so I ordered minimal. My GF4mx which was on my old comp is goign to be replaced by a Radeon 8500LE, Im adding another 256MB (same kind) and getting a sparkle 400W
specs:
Turbolink 350W PSU
X-sonic case
cooling:
