so.... my first real overclock on my first real CPU cooler... and what a ride.
i started with a goal of 4ghz on my 1090T.... wich ended up being at least 4ghz, 2800 cpu/nb, and under 1.5vcore and 1.45 cpu/nb.....wich i have done
system specs, cuz lol.
msi 990fxa-gd80
1090t
- vcore in bois 1.388 (windows is slightly higher, 4 hours into prime95, cant stop to look. load is 4.88/4.96.... and it just pisses me off.... why is it higher?)
- cpu nb freq @2800, 1.36V
-ht 2000mhz, 1.22V cuz a slight bump dosnt hurt
- nh-d15 cooler, temps not over 45C 6 hours into prime
16gigs muskin ram at 8-8-8-24 1.55V
msi 6970 lightning
basically.... did i do anything wrong? my volts are a tad to high for 24/7 (and i use this PC 24/7) but my temps are so good i figured im not going to degrade it that fast.... and if i do, meh... time to get a new mobo and AMD cpu.(would still like input if too high) hopefully the new cores set to come out 2015/2016 are decent....the dude who did all the socket 939 chips is back, and making a enthusiast x86 chip!!!
from looking around, ive gotten a decent OC, and great temps. and my sensor is spot on... +3cish over ambient at stock with nh-d15.
any way i could get more out of her? the mobo ramping up the vcore under load is dumb as hell..... first off, i tell you to run at 1.388 in the bios, stable at 4ghz or not.... your sposed to Vreg with your Vregs to 1.388V. this Vcore is looked at in cpu-z and MSI control center. in bios its still higher, but not as high as when under prime
then i offset for vdroop old school style....... why does it do this? P states?
i have c1e, coolnquite, APS power phase, ETC all set disabled.
i hear some 990fx boards have a LLC setting.... mine does not. MSI 990fxa-gd80 is a great mobo for stock stuff.... but idk about OC
the cpu wont work right one setting under 1.388 in bois, even at 4ghz. however, i know, that with a smaller jump in settings, and a MoBo that actually held its voltage, i could drop my vcore .05 maybe even .1V
also, what about raising the HT link speed? i hear thubuns like it bumped, then i hear it lowers performance.... im 4ghz stable at 2800cpu/nb and 2000ht. the fastest i can go on this mobo is 2600 mhz ht link. the cpu/nb link also got buggy under prime at 3ghz, and i attest this to this mobo.
ive learned that my chip does not like 4.2ghz even at 1.55volts (still had great temps) however, i also had a LOT of other issues i had to sort that were also causing problems, but the error codes (1e) made me thing i needed a vcore bump that i wasn't willing to make. it probably would hit 4.5ghz, but not be 24/7 OK
just to reiterate, are my voltages OK for 24/7 at thows temps?
is that a good oc?, or am i a noob and totally have everything set wrong
why is my mobo upping the volts? seriously, why. about to email MSI asking for a BIOS with LLC and ofset
what about c1e and cool and quite.... i would REALLY REALLY like to enable this so i get lower temps, and lower volts, thus, longer life. i hear a program called phenom rtss or something like that allows you to set custom voltages at p0/1/2/3/4 states. i want my .5V at 800mhz!!!
but im mem test and prime stable at 4ghz/2800mhz with decent ram timings (might try to get 7-7-7-24 or lower its muskin redline after all)
EDIT. i just physically touched my NB and Vreg heat sinks.... they both are hot as hell. hopefully they dont make me fail prime/fry my stuff....... my 120mm rear fan died just before i got my nh-d15, but i do have a 200mm top right above the CPU sink. ill just tip a computer duster can upside down for poor mans LN2 vreg cooling.
again, i call into question just how good MSI mobos are. i thought they were basically all the same, with only minor differences in BIOS between any high end 990fx, but ive seen reports of MSI saying that their boards like the 990fxgd65 cant support +95W cpus and that this mobo cant do over 125W......so no FX-9xxx chips (wich are CRAZY to run at 5ghz and at that Vcore)
msi 990fxa-gd80
1090t
msi 6970 lightning
