Yes, I had the 1090T in a GA-890XA-UD3 which had a 790X chipset with an SB850 SouthBridge. It was basically a slightly updated GA-790X-UD4P. It could even take the heatpipe cooler from one, so I swapped the coolers as well.
As far as improvements, one of the largest is chipset and VRM cooling. Though that's because it's a higher-end board. Both the 790X-UD4P and 890XA-UD3 needed a 60mm fan to keep temps under control.
Performance-wise the new chipset alone is worth half a second in SuperPi after consistent, repeated runs. That was one reason for upgrading the board. It has slightly higher memory throughput.
Another advantage is that it can achieve the same overclocks with slightly lower voltages, at least in my case. The 890XA-UD3 took 1.55v to run the 1090T at 4GHz. The 990FXA-UD5 takes 1.525
If you have a true 890 chipset, the differences aren't very much. But if you have a 790 chipset, it makes a nice improvement.
