- Jun 6, 2002
Agreed, quad SLI is hilariously useless.
A single 9800GX2 would also do you well, maybe better than a 4870 if your running a higher resolution. (correct me if I'm wrong). Looking on newegg you can get either or for $289.99
that is true but depending on the game the 9800GX2 will be out done slightly by the 4870. as you can see in this vga chart from guru3d in crysis
http://www.guru3d.com/category/vga_charts/
one thing i find odd is the lack of CF'd 4850/4870 numbers. maybe issues with drivers? who knows? my take would be a different route then those 2 cards and be out done for not much more. 48050 in CF at $169 atm on newegg http://www.newegg.com/Product/Product.aspx?Item=N82E16814102747
or if your ok with MIR's get them close to $150
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161235
people need to pay close mind to the games they play or might play. imo that is the key factor to what cards to get. as ATI's 4800's do better in some games vs NV's, even in a CF vs SLI setup. as you can see by the VGA chart...
