- Jan 12, 2005
- Houston, Texas
BUILD IT YOURSELF OR YOU WILL BE SACRIFICING YOUR COMPUTERS PARTS!!
Dreamstalker said:Here's mine, for reference:
--64 3500 Newcastle
--XP-90 (don't have 'proper' fan yet but bf is loaning me a 70mm screamer for temporary use)
--Asus A8V Deluxe (non-PCIe although PCIe board prices should be coming down later this year)
--1GB Mushkin (2x512)
--ATi Radeon 9550
--Fortron BlueStorm 500W
--Plextor optical drive (CDRW/DVD)
--Samsung 160GB SATA
--Tt (I know ) SViking (it has the cooling I wanted and was within my case budget at the time).
Total: $1200 (give or take; my math may be slightly off).
Speedguide.net has a tutorial on building PCs (don't have the URL handy); the General PC section of any major bookstore should have computer building books.
EDIT: Here you go, not the speedguide link but it's a start http://www.ocforums.com/showthread.php?t=90594&page=1
aeiou said:its really true. There aren't many companies that will alow you to choose every component. Even when the ydo, it is a limited list and they charge a premium for this. Try to build it yourself. Buy a good book on building and/or ask questions here. Even the cooling part is really easy if you're careful and I'm sure we can walk you right through it. You be happier that way. Believe me.
fultz said:So if you are careful, but don't know what you are doing, it's IMPOSSIBLE to destroy a computer component? If I did destroy a component, would the manufacturer or store refund or replace it? That's all that's holding me back is the fact that im afraid of messing something up.
The main reason I got a Newcastle was because I wasn't sure what revision my mobo is, the earlier one has issues with Winchesters IIRC. Also Winnies were out of stock at the store at the time (this initial build is an academic credit project, so I wanted to get all the parts as quickly as possible). Some OEM's do use Fortron PSUs; my dad has a RadioShack compy with one.fultz said:I need a DVD Burner... your power supply is massive, I also want the winchester chip because I heard the new castle chips don't overclock very well.
Eep...that's why I went without. IMO, by the time there's software that takes full advantage of PCIe/SLI it'll be time to upgrade anyway I'm building from scratch though, so YMMV of course.I tried alienware, the system is almost $1900 without SLI. :|
fultz said:How much would that system be if that was a 6800GT PCIex16 instead?
NO LIFE said:unless they give a brand you can assume the powersupplies that come with those cases are ****, to be frank.
Did ya get my PM?
