- Sep 7, 2013
Use hyper Pi to stress the NB. Either that or Minecraft.
If you dart around the map in Minecraft then your NB is unstable.
For reference, I can go as high as 2450Mhz NB before no amount of voltage gets it stable.
VDDA, I have found keeps the Vcore fluctuations on the higher end. My Vcore bounces between 1.42 and 1.46 under load. With VDDA set to 2.8 volts, it stayed mostly at 1.46. With VDDA set to auto, Vcore sat at 1.42 more often. YMMV, this might just be my board acting funny.
CPU/NB is the NB in the CPU.... AMD has 2 NB's. One one the CPU and one on the motherboard.
CPU/NB voltage would be the one you want here - that's the CPUs NB.
NB voltage is the motherboard's voltage. For higher FSB and such IIRC.
NB 1.8 would probably be "NB termination voltage" That's my best guess as I have a similar option on my Gigabyte board. I don't touch that voltage.
