- Thread Starter
- #21
its nearly finish ..and maybe another gtx 680.Like it a lot, very crisp craftsmanship on the WC
but have to find why only show 8 gb of ram ..
so what i should set in bios for igpu?
Chuckles.....21 replies and noe suggested checking in Windows if max memory is checked.
Go into MSCONFIG, then BOOT, then ADVANCED OPTIONS, uncheck MAXIMUM MEMORY
Luke1978 said:If it were me I'd double check the socket and CPU to make sure all pins etc are in good working order, and then look into the board being faulty.
If the other CPU you have correctly shows all 16gb then you can say with reasonable assurance that its the CPU at fault.
I had the same problem (16GB installed and visible in bios but only 8GB seen in windows)...turned out to be a bent pin in the cpu socket so second Luke's recommendation.
but vhen Im booting...bios show only 8gb ram
You posted a screenshot of the bios recognizing all 16 I thought
:edit: memtest is the ss you posted
I will replace cpu with i5 3570k soon and will report whats happen
