I just bought a 1ghz CPU and abit kt7a-raid on da weekend and set it up just yesterday. OK, the only problem is heat. 53c with Quake3 after 10min. I dont know what the problem is because I have another computer with the exact! same setup and its running 44c max with Quake3. I'm using superorb on both comps. I mean exact setup, part for part but the case design is a tiny bit different. Both cases are full towers with 3 fans installed. Basically, there is no physical diff in the cases.
Actually, the only real difference I know of is that her CPU is 200FSB B stepping and my version is 266FSB C stepping. Both chips are at 1Ghz too.
HELP!!, maybe the CPU is diffective or m/b is reading an inaccurate temp?????
