- Jan 16, 2010
i stuck a second fan ontop of the stock fan on a hd 2600 xt 512.its exactly the same size an everything.smart or dumb? lol
It isn't moving air faster.when i place the fan ontop it seems to almost double in speed...just thought the quicker i mave the air through the heatsink,the coller it will stay. ill post tomorow after i do some benching and well see
There is another factor at play. You are making assumptions that are not correct. Yes, adding a fan may have reduced the temperatures, but that doesn't mean it proves physics wrong.ok,sorry it took me a bit to get back to this.i just did some benching and WITH the 2 fans i got a steady temp of 75 whilst running ati tools 3d renderer for 15 mins or so.as soon as i took off the second fan the temp went up to 80+. kept the renderer runnig the whole time,put the second fan back on and it very quickly went back down to 75-74.so the verdict is that it actully does work fairly well inseed(as i had allready surmised)
As I posted earlier, putting them in series increases the pressure of the fans in a perfect world. If there is enough resistance, adding a second fan may increase the pressure, which would mean that more air gets pushed through the heatsink.
Think of it like this: You have two vehicles and you bolt them together. It does not make them accelerate faster (CFM), but it will increase their total towing capacity (pressure).
For the future, it would probably be best to get a thicker fan. This way you eliminate the inefficiencies of trying to get two fans to work in tandem and you get the lower temperatures that you wanted.
It will work, i remember doing it many many years ago - putting a 120mm fan on stock Celeron 300A heatsink using a cardboard "cone".ya,iv never pulled apart the fan/heatsink assembly on this card but im sure i could prolly pull the stock fan out and strap on a big one with some kinda ducting i suppose
