While messing around inside my Cooler Master Storm Trooper case, I managed to tug on a case fan cable and separate the two wires from their respective 2 pin fan header. If I knew which wire went where, this would be an easy fix, but alas, two wires are colored identically and bear no distinguishing marks from one another.
Does it matter which is which, and if it does, is there any way for me to distinguish between the two? Will trial-and-error potentially cause electronic problems with the fan/fan header? How bad of a mistake was this?
