- May 22, 2016
Okay, so the first part of pre-mix vs distilled. Thermaltakes water cooling kit specifically says to use pre-mix fluid only instead of plain distilled water. Any reason for this? I've only ever ran distilled in all my loops, mostly because when I first got in to water cooling the dyes breaking down and clogging the system was a big concern. Is distilled really going to cause any issues?
Secondly, is the Laing D5 pump enough to handle a CPU block, GPU block, and a pair of 360mm radiators? I'm looking to make a new setup with a pair of 360mm radiators and I'm hoping to keep it one loop vs two.
