- May 26, 2015
- California
I'm confused about CPU and system fans interfacing with MB speed controls.
Of course, 2-wire fans are one-speed...but why do CPU fans have both 3- and 4-wire connections?
I was under the impression that 3-wire fans could be speed-controlled by the system BIOS to respond to increases in CPU/system temperatures as reported by the sensors. For testing while I wait for a good deal on a newer/faster CPU I am temporarily using a 3-wire CoolerMaster heatpipe-tower CPU cooler in a recent build (not on the system in my sig) with an AMD Phenom II 720 from another older box.
The CPU cooler seems to be working with the fan at full (?) speed (an indicated ~1900RPM), and the CPU as a consequence just barely makes it past ambient temperature at sustained 100% load. In the BIOS I have fan speed control turned on, which I believe is default.
So, what's with this? Shouldn't this fan be barely spinning? Am I wrong and ~1900RPM is relatively low-speed and this is just the lowest available speed increment? Is variable fan speed unsupported by this older CPU? What?
Why do some of my newer CPU coolers have FOUR wires going to the CPU Fan plug?
Many thanks for any clarification!
