White Wind
- Mar 22, 2014
Hi guys I'm gonna build a system ( first time ever ) it will primarily be used for hardcore gaming, running VM's and a bit of video editing, and maybe a bit of benchmarking.
What I want to watercool is :
- an overclocked 4670k ( but later that may be a higher-end cpu )
- two overclocked gtx 880's, that's for later obviously
- maybe one or two mobo blocks too ( for now it's a Maximus VI Gene )
- and maybe my psu too ( a Super Flower Leadex 1300W gold )
There will be two pumps and the case will be the Phantom 410 mid-tower case.
I want to be able to push wild overclocks ( if chips agree ) and remain as cool as possible, while keeping my fans at low rpm to keep them as quiet as possible... that's why I decided to go with the Phobya Xtreme SuperNova 1260 external radiator, which can handle that heat silently ( and which seems to be more suited for low rpm fans than the MO-RA3 ). Its size : 460 x 420 x 46 mm.
It can be mounted with 9x 140mm-fans or 4x 200/220mm-fans, and I've decided to go with the latter since I'm aiming for low rpm.
Now.. I find it pretty hard to gather info about big fans mounted on rads, and the few tests I've stumbled upon are a bit outdated ( 2009-2011 ).
All the tests of the Phobya 1260 I could find have it mounted with 4x 200mm Cooler Master MegaFlow and 4x 220mm Yate Loon D22BL-12H.
So all in all, here is what I could come up with:
- Yate Loon D22SL-12H 220mm...600rpm ( not on a rad ): 61 cfm / 32.3 dB ( low static pressure )
- Yate Loon D22BL-12H 220mm...750rpm ( not on a rad ): 76 cfm / 35.3 dB ( low static pressure but it has proven it can get the job done fairly well on a Phobya 1260 ...but too noisily ? )
- Cooler Master MegaFlow 200mm, less performant than the D22BL-12H, but produces less noise ( both compared on the Phobya )
- Antec Big Boy 200mm..............600rpm ( not on a rad ): 47 cfm / 28.5 dB ( has good static pressure, at max speed of 900rpm it is too noisy at 37.4 dB )
And that's it.. I'm at a loss regarding what to choose or where to find more recent info. If you guys know about better fans than those for the job, or would pick one in particular among these, well.. I'm all ear ^_^
Oh, and I still don't know if it'd be better to go for a push or a pull config. I think there are fans that do better at pushing or at pulling, that may be something to take into account.
Thanks !
Thanks !
