Skiggygore
- Oct 29, 2017
Hi guys, Im going really overkill on fans in a Corsair 250D but theres one problem, the h100i v2 I choose has very thick and hard to move tubing and its impossible to get the motherboard in there without the I/O digging into the tubes heavily.
Photos -
So Im hoping you guys would be able to help me find either a thinner radiator, a one with smaller tubing, or one that could fit with the tubing in the tiny space between the 5 1/4in drive tray and the wall. I also need it to be fairly durable and low maintenance because this computer will be with me on the road. Thanks for any help you can provide!
NOTE - I have no experience with soft tubing or hard tubing. This is only my second build so I might need some explanations of things.
- MSI Z270I GAMING PRO CARBON AC MINI ITX LGA 1151
- Corsair 250D Mini-Itx Case
- 3 Delta 120mm fans
- 2 Delta 80mm fans
- Lamptron CF525 Fan Controller
Photos -
- 2 Delta 80mm fans
