- Jan 2, 2015
- Sydney, Australia
- Thread Starter
- #121
Hey guys,
Here's another update on this build! Most of the fittings and cables are now in and it's ready for tubing up! Just wanted to give you guys a quick look inside before tubing up.
That chrome colored fittings is the only straight rotary fittings that I had. Once the front radiator is in that fittings is not seen.
You can also see the LED strips are in, these are UV LEDs from Icemodz.
Not sure if you notice but I bent a piece of acrylic around the 80mm fans and also around the 140mm fan, thought it cleans things up a bit.
Thanks for checking it out!
Cheers,
Alex
