- Sep 23, 2002
- In a **** hole dorm in Iowa
I suppose I should start off with specs:
A7N8Xdlx 2.0 bios 1007
2600+ @ 194x12.0, 1.775V
XMS3200 512 (1 stick) @ 11-3-3-2, 2.6V
Radeon 9500PRO flashed to 9700PRO @ 310/290, 1.6V
Audigy2 ZS Platinum
WD 40.0GB 8meg cache
I know the system can do more, but lowering the multi and going higher doesn't yield good results. programs start crashing to the desktop @ 196, even with more voltage. 11-2-2-2 mem timings cause horrible errors like bios checksum errors and bsod's right and left, more voltage seems to do the same. my temps are an incredible 45-46C load, I have an slk-700 with a 5500rpm ys-tech fan and the case has...8 80mm fans plus two on the 450W Codegen psu.
I have every extra turned off in the bios.
I'd really like to hit a stable 200+, but I can't seem to think of anything else to try.
Audigy2 ZS Platinum
