CF/SLI is helping in nature test only. If you make it work good then 2 gpu score can be higher than single gpu. Point is that most drivers are slower in SLI/CF and for every card it looks different so there is no rule which driver is best. In most cases nature score can be higher but some other tests will be lower so in total all depends from CPU and how high it will bump 1st tests.
btw -> 32GB Patriot Viper 2400 CL10@ 3100 , and I can only say that there is no point to push memory above 2666 on X79 boards. Higher clocks = more relaxed timings = lower performance and much higher latency.
