Difficult benching the past couple nights
With 2 cards, was and am still not able to get sli working in XP (tried 285.xx as well as 310.90 and 320.xx). The sli settings don't even appear in NVCP. SOOO frustrating!!!! Tried with 7x64 to see if there was some other problem but 2x sli works np with that os (haven't tried other os'). What the heck???
Decided to rtfm again...the mobo's a pita! There are the following pci-e slots: 1, 2A, 2B, 3 and 4. Here's what it wants:
4x sli- slots 1, 2A, 3 and 4
3x sli- slots 1, 2A and 3
2x sli- slots 1 and 2B <---- arghhh!!! PITA!!!
Thinking that to get them working properly under XP I'd have to tear down the quads and then add a little space between the first and 2nd cards so that I can fit the 2nd one into slot 2B. I may have to swing back to these cards at a later date (the quads will fit more or less as-is into the rive)...maybe go ahead and do the 1x 3D's before moving on, though...will think about that a bit.
Did do a couple test runs last night. My 3dm01 score is absolutely atrocious (
http://hwbot.org/submission/2511603_funsoul_3dmark2001_se_2x_geforce_gtx_580_89348_marks ). Comparing against other setups, really looks like I should be hitting in the 120k-130k-ish range.
Also had a bugged 3dm3 run (
http://www.3dmark.com/3dm03/6515310 ). Didn't bother to submit it because it's clearly a bugged run (and also because I didn't get a screenshot)....the setups with similar scores are much faster than what I'm running.
