- Oct 7, 2015
- Lindfield, Sussex, UK
Hello all,
Well after planning a system using AIO coolers and being talked out of it on here I have gone away and done my research on a "proper" water cooling loop.
Have to say I am more confused then ever not least because of the lack of decent, (current) information on 280mm rads and fans.
My new system will be comprised of the following.
Corsair 730t black tower case. (purchased to use as a recase of my old system with extra clearance for the lowest GPU)
Intel i75930
Asus X99 Deluxe mobo
32gb HyperX DDR4 (4x8)
FXFX 1050w psu
2x Asus GTX980 Poseidon
A selection of HDD, SSD, slim opticals etc.
As far as water cooling goes I have started puting some bits together as and when I see a bargain.
XSPC D5 Vario Photon 170
EKWB Supremacy evo
Earthdog was kind enough to give me a few pointers and recommended a minum of 5x120 rad for this kind of loop.
Looking around and at the case 120 rads seem a waste of space as I have mounting points for a 280 in front and up top with a possible 140 on the back and a 120 in the bottom.
Would 2x280s be enough for general needs?
The increased size is roughly comparable to 5x120s.
From what confusing research I have done and accounting for my budget, I have kind of settled on mounting NexXxos xt45 280s. Temptation wsa to go for the slimmer model but the price difference is minimal.
Fans is a complete nightmare.
A lot of comparisons are now several years old and others just give conflicting results. Add to that I don't really understand if I need Static pressure or airflow fans and how to mix, or not.
Again budget is a concern.
I'd like to aim for about £5 a fan as I am sure I will be recommended to go for Push and Pull so minimum 8 fans.
Yesterdays research came up with this offering which seemed to be liked by the reviewer and compaed well to the rest of the fans.
Thermalright X Silent Eleven 140mm.
The new system will start out not being over clocked whilst I iron out the lops and get it settled to something I am happy using.
In the future I will explore Overclocking the CPU and GPUs to gain some performance for things like graphics and video creation / editing. I also do some 3d work occasionally so anything to help cut dowm render times is good.
Short of buying tubing and fittings it's really just deciding on the fans and rads that is stopping this build now so any advice, pointers and guidance would be greatly appreciated!!
Main aim is to keep the heat out of the case and keep it quiet.
Intel i75930
FXFX 1050w psu
EKWB Supremacy evo
