Click on the Start Button in the lower left corner and type in "disk management", which is where you want to go in Windows.
It may say "Create and Format Hard Drive Partitions". Click on that to take you to Disk Management. At Windows Disk Management, see if your drive shows up. You may only need to format it, which you can do from Disk Management. Good luck.
