- Nov 24, 2001
- Dallas, Georgia
matttheniceguy said:The TEC cooling the TEC that is cooling the heat load absolutly has to be larger than the first TEC. For the cold side of a TEC to be colder than the Hot side, the TEC has to be pumping less heat than it is rated for. If a 100 Watt TEC is given a 100W load, the Cold side won't be colder than the hot. If you try to get a 100 watt TEC to cool a 150 Watt TEC and a heat load, well you won't be cooling a thing. All the the pelts and the heat load will quickly heat up to the point of them all frying.
Gotta tell ya I agree with you in most everything except that the tec cooling the tec. Lets reduce the heat load that the second tec sees and we should have a viable solution. Call it augmented tec cooling if you will. If the second tec only sees a 60 watt load then all is good (w/ an 80w tec). It is happy and the 226w sees a hot side that is better than ambient would be. Possibly an air cooled second tec.
