Heres a little story for you, my board will boot fine at my oc settings, then ive been playing a game fah still running so the case is warm inside, soon after i decide to reboot for whatever reason, pc comes to post no boot blank screen, i then have to hold down the power button for it to turn off, then wait about 5 mins before trying again. Although on the second boot if i try straight away the pc will boot but @ 2.8ghz and say oc failed, if i then press f1 to change my so called 'failed overclock' settings just go to discared changes, then wait for it to contiune to reboot, and press CTRL+ALT+DEL before windows begins to boot, 9 times out of 10 the pc will boot at overclocked speeds.
This sounds like the problem which you have, i find it happens more late at night as well, (when its alot warmer in my room).
