I just got a new mobo/cpu combo and I have 3 choices as to what cooler to use without putting out any more $ to get something else. The answer is a bit complicated due to mounting. The Cpu is an AMD fx-8320. So here are my three options, what would you recomend and why?
1) Default AMD heatsink. Small, light, does have heatpipes, 70mm fan.
2) Zalman CNPS5X. Small, light, heatpipes, 92mm tower. Suggested for 95w but see #3.
3) OCZ Vendetta II. Large, heavy, heatpipes 120mm tower. Built for higher wattage than #2 and based on all online reviews I've found it beats the Zalman but it can only be mounted the "wrong way", top-to-bottom, not front-to-back, so it has limited airflow.
