@PolRoger,
So how does your ram overclock compare to IB? DDR3-2400 CL9 at 1.625v looks pretty good. Were you able to run those same specs before? Are those one of your GSkill kits?
As the second person to actually apply the guide (EarthDog was the first), what do you think of it? Anything missing? Tips that worked...or didn't? Any tips to pass on yourself?
I haven't been on the OC Forums - and this is what I find? How long you you ask (IIRC the USB bug in the Sandy Bridge days).
@hokiealumnus: Thank you for the guide. Is it really this easy? CPU speed first and them Memory speed second? As long as you have good air/AIO water - you don't have to worry about the heat.
I thought I saw it posted somewhere that O/C are:
50% xxxx speed
30% xxxx speed
10% xxxx speed (which I think was 4.7 - 4.8[?])
@PolRoger: You sir must be 1) Very talented 2)Very Lucky and godlike. You are at 4,700 @ 1.26V. I understand that is with your temps @ ~85?!?!?! That is mind blowing!
I know I going to get a for the system that I use everyday (It is worse than you think - it is NOT the rig in my sig). I figure that I have to bite the upgrade bullet at some point and it is either Haswell or Ivy Bridge.
Thanks Again everyone!
1. Approximately 70% of CPUs can go up to 4.5GHz – Overall you will find most CPUs capable of reaching 44x to 45x with varying levels of voltage. Voltage will be a key item as it will define the maximum thermal output and as such will dictate whether the frequency can be held with stability as well as with sufficient cooling to allow for normal usage.
2. Approximately 30% of CPUs can go up to 4.6GHz
3. Approximately 20% of CPUs can go up to 4.7GHz
4. Approximately 10% of CPUs can go up to 4.8GHz
Nice PolRoger...did you try for higher clocks? And what about ram?
Hey PolRoger, what do you think of AIDA64 stability test?
