azianese said:nobody likes corsair brand anymore?
nicknomo said:People are too picky.. Corsair/OCZ/G Skill are all using the same chips. Thats why their benchmarks right now are almost identical.
an extrea 5-6mhz either way, won't make a lick of difference.
nicknomo said:With other manufacturers, you may get memory capable of this, but it isn't seperated through binning. So you don't know...
TombKeeper said:test your system at the various speeds and see what kind of gains you get as your fsb goes higher.
glock19owner said:There are some other factors that also must be taken into account when making this statement...
1. 1 out of 10 chips are used for the LE's (some do not even make it to LD standards)
2. G. Skill does a very stressful stability test to make sure all memory that is on all of its models will do both PC3200/PC4400 speeds at the rated models timings...and in the case of the LA's...DDR600 rated...
3. G. Skill uses its own brain PCB setup...so the PCB's are not totally alike
4. G. Skill is the only maker out that gaurantees that all models..(except the LA's) run at PC3200/PC4400 and in the LA's case DDR600 specs for a lifetime...
I am not knocking or will I knock OCZ and its products...but G. Skill does go over and above what most other companys do to make sure they have some of the top memory out right now
TombKeeper said:You think there would be such a big diff in speeds (real world apps/games not benchmarking scores) between 300x9 and 11x245 ? And I mean something we would notice (ex 55 fps in a game versus 45 fps or something....not 210 fps versus 200 fps because who cares about fps above 60fps)
