Isn't it sad Alaric, not only is it tough to even hold the the MM on the read points because you can barely see them, due to the peepers getting old. While doing so, you can barely see where the analogue gauge is pointing. I used to have perfect vision and in the last year they've gone to @#$% !!!!I learned on an analog meter (big heavy sucker), but I'm spoiled now and prefer my digital one. It's easier to read on the tiny solder points on the mobo. Trying to see if the needle is lined up in the mirror of an analog dial while not twitching and shorting my vcore to my vDIMM is too much like work. LOL
If it's the ram in your sig then you're likely in luck. I think those kits were Samsung so a bit of voltage and tweaking should get you going faster. Should be able to run 3466 at CL 14 with minimal voltage increase
Dam Al, I'm jelly! You running that 3000 ram @ 3866. My 3200 set is just barely over 3433 with the same timings and 1.365v. I'm gonna have to hunker down and try again
