- May 14, 2015
I'm looking at some noctua fans as part of QoL choice upgrades for my case, particularly the new A series 120mm and 140mm fans, and I noticed that the noctua fans are PWM(4pin), the fan hub in my case, and my fan cables are 3pin.
I have a various mix of fans in my case already, but they're mismatched, it annoys me a bit and I'd like to give Noctua a shot, as their new A series looks interesting. but again the fan connection system in the case is all 3 pin.
Obviously without a PWM singnal you can't control the fanspeed, but the case has a built in fan speed controller anyways.
10 connection fan hub, manual speed switch.
Question: Can you use 4pin PWM fans as if they were 3 pin standard? Will they just run at the max power that's delivered to them or do you need the PWM signal to make them run?
