- Jan 27, 2006
hey guys, I'm a newb when it comes to fan control. i just bought my self a new case (corsair Air 540) the case fans that come with it are all 3pin. (my cpu fan i use is also 3pin) i just came from a case that had a low/med/high switch attached to the fan and ran off molex (antec 900v2 case). i've never screwed with 3 pin or PWM fans before so i have no idea what I'm doing lol. my motherboard (info in sig) has 2 PWM (4pin) ports. 1 for cpu one for case fan. other 2 are 3 pin.
the question i have is is there a way i can control the fan speed of the fans that are running off the 4pin PWM ports (even though they are 3pin fans?) the asus motherboard as a chip on it which in use with their fan xpert software, i can control the fans within the OS. i tried it and the 2 fans running off the 3 pin ports on the motherboard work and i can change the fan speeds for them. but in the program i don't get an option for controlling the one PWM port. I get an option to control the CPU PWM port, but does not seem to want to work and my cpu fan speed stays locked at its max speed
what's a good 5.25" bay fan controller (does not need to be fancy and have touch controls, nobs are fine) and do these fan controls work with 3pin fans or only PWM fans? or would i need to get Voltage regulator adapters (3 pin to molex adapter)
thanks and hope you can help me out
