- Mar 3, 2003
- Toronto Canada
- Thread Starter
- #21
but in all honesty, the most multitasking i ever do is opening more then 1 IE window at a time... I dont need to burn a disc and play a game at the same time.
Graphicism said:If a CPU isn't at 100% you wouldn't notice a stutter anyway. Therefore when I said HT kicks in at 100%, in lamens terms you will only notice it at 100%. HT doesn't open a special portal that overclocks the CPU when it needs it or plucks some magic GHz from no where, it's just good at managing. It doesn't say process-A is taking up 100% cpu, let's magicly give process-B 25% cpu... instead it takes the 100% process-A and put's it at 75% top CPU usage allowing for process-B to use 25% cpu usage.
Thats the reason why they don't use HT when benchmarking.
Vio1 said:but in all honesty, the most multitasking i ever do is opening more then 1 IE window at a time... I dont need to burn a disc and play a game at the same time.
That's what I said, the only difference is I just don't sound like a spokes person for intel.Albuquerque said:Hyperthrea ... esult.
1.6 is considered safe for the MOBO Vreg circutry. and even with that at your speed it will be very hot. Active cooling would be nice even if it's a fan over the mossfets. as far as the chip, dunno how high that should go. but mobo prolly die before the chip.Vio1 said:Anyone know the max safe voltage for pressies under vapochills?
No, you really didn't. You said:Graphicism said:That's what I said, the only difference is I just don't sound like a spokes person for intel.
Incorrect. It works at all levels of utilization.but HT is only enabled when the CPU hit's 100%...
Incorrect. It works at all levels of utilization (again)but clearly it doesn't take effect until you hit 100% cpu right?
Incorrect. It does not perform any sort of load balance, nor does it "deprioritize" individual threads.instead it takes the 100% process-A and put's it at 75% top CPU usage allowing for process-B to use 25% cpu usage.
Vio1 said:Ok, i have a new question: Is there a noticeble performance increase running a oc computer with memory at 1:1?
Currently my computer is overclocked to 16x281fsb = 4500mhz however im running my ram at 5:4 or 225mhz. Would I notice an increase in performance if I replaced my OCZ PC3500 EB with lets say PC4500 (or something that will reach 281mhz)
Worth my time and effort? If so, what ram would you recommend?
