Dummy check would be to make sure you are pushing the tab that holds it in... yes its "obvious" but I've been guilty of that myself.
That said, try a small squirt of wd-40 (let it sit for a minute). WD-40 is non conductive and cleans up easily so it wont harm anything. Dont go crazy and spray everything, just a small amount to lubricate the plastics.
