- Aug 2, 2012
I am looking to build a PC based around an EVGA Z97 FTW motherboard. This board has a 6-pin PCI-E connector that is required when running SLI. It seems like most PSUs that are in the right wattage and price range only have 4 PCI-E connectors. I would rather not limit myself to GPUs with a single 8-pin if I don't have to. However, it seems like any time I find a PSU with 5+ PCI-E connectors, it's 850W+ and/or 80+ Platinum. The cheapest I could find (worth buying) is the Corsair AX760. But a 4790K and dual 980s would be under 500W, so it seems like overkill.
Any suggestions for sub-$100 PSUs with 5+ PCI-E connectors? Should I bite the bullet and go with an over-the-top PSU? Should I bite the other bullet and accept that I will need to have GPUs with single power connectors?
